PublishSingleFile=true for .NET
The build 1932 supports self-contained executables.
Here is simple example of .csproj to protect compiled assembly before publishing in a single file:
<Project Sdk="Microsoft.NET.Sdk">
<Target Name="VMProtectCompile" BeforeTargets="GenerateSingleFileBundle">
  <PropertyGroup>
    <VMProtectCon>"C:\Program Files\VMProtect Demo\VMProtect_Con.exe"</VMProtectCon>
    <VMProtectInputFile>"$(IntermediateOutputPath)$(AssemblyName).dll"</VMProtectInputFile>
  </PropertyGroup>
  <Exec Command="$(VMProtectCon) $(VMProtectInputFile) $(VMProtectInputFile)" />
</Target>
<Target Name="VMProtectDelete" AfterTargets="GenerateSingleFileBundle">
  <Delete Files="$(IntermediateOutputPath)$(AssemblyName).dll" />
</Target>
</Project>
howze
Re: PublishSingleFile=true for .NET
Post by howze »
Admin wrote: Wed Dec 27, 2023 11:17 am The build 1932 supports self-contained executables.
  <PropertyGroup>
    <VMProtectInputFile>$(IntermediateOutputPath)$(AssemblyName).dll</VMProtectInputFile>
  </PropertyGroup>
</Target>
</Target>
</Project>
1、When I was testing this feature, I found that if the name of the project contains a space, it will report an error when publishing, please check, thank you.
2、At the same time, how to use functions such as 'Memory Protection', 'Debugger', 'Virtualization Tools Found' message, etc., which can be directly used in the gui?
Just change PATH_TO_VMP_FILE to the full name of ".vmp" file created by VMProtect's GUI:
  <PropertyGroup>
    <VMProtectProjectFile>-pf "PATH_TO_VMP_FILE"</VMProtectProjectFile>
  </PropertyGroup>
  <Exec Command="$(VMProtectCon) $(VMProtectInputFile) $(VMProtectInputFile) $(VMProtectProjectFile)" />
</Target>
About available parameters for the console version you can read here.
P.S. Don't forget to use the code virtualization for all critical methods with ObfuscationAttribute:
[Obfuscation(Feature = "virtualization", Exclude = false)]
void MethodForProtection()
howze
Post by howze »
Admin wrote: Fri Dec 29, 2023 12:21 pm Just change PATH_TO_VMP_FILE to the full name of ".vmp" file created by GUI:
  <PropertyGroup>
  </PropertyGroup>
</Target>
I don’t know if I understand it correctly, but I still get an error.
  <PropertyGroup>
    <OutputType>WinExe</OutputType>
    <TargetFramework>net8.0-windows</TargetFramework>
    <RootNamespace>Wpf_App</RootNamespace>
    <Nullable>enable</Nullable>
    <ImplicitUsings>enable</ImplicitUsings>
    <UseWPF>true</UseWPF>
  </PropertyGroup>
  <PropertyGroup>
    <VMProtectCon>"D:\VMProtect Demo\VMProtect_Con.exe"</VMProtectCon>
	<VMProtectProjectFile>-pf "C:\Users\Hao\Desktop\Wpf App\bin\Release\net8.0-windows\publish\win-x64\Wpf App.exe"</VMProtectProjectFile>
  </PropertyGroup>
</Target>
</Target>
</Project>
It seems you don't need our software, because you can't even solve such a "simple problem" by yourself. I don't understand why you think that "Wpf App.exe" is a VMProtect project file.
P.S. You still use wrong code here:
howze
Post by howze »
Admin wrote: Fri Dec 29, 2023 2:29 pm It seems you don't need our software, because you can't even solve such a "simple problem" by yourself. I don't understand why you think that "Wpf App.exe" is a VMProtect project file.
Thank you very much, I successfully solved the problem, it was indeed that I used the wrong code.
ps. My English is not good, and I am not very familiar with this software, but now I understand what VMProtect project file is. Anyway, thank you again for your patient answer.
