- Capture.JPG (7.01 KiB) Viewed 4619 times
vmp 3.8.5.1879
vmp 3.8.5.1879
this error I get while protecting one vmp sdk dll.
Re: vmp 3.8.5.1879
Are you a registered user of VMProtect?
Re: vmp 3.8.5.1879
yes I am legit user, just reporting bugs.
Re: vmp 3.8.5.1879
This bug was fixed.
Re: vmp 3.8.5.1879
true fixed in 3.8.6 b1953
size of same protected file using 3.8.6 same settings from 3.7.3 is ~ +70% bigger
speed for loading same protected app is ~ +25% slower.
is there planed for future builds a way to select disable some protection features to gain more speed.
because customers angry and not all have patience for that few extra more seconds to wait.
I know more speed may be low protection in complexity.
thanks !
thanks !
