VMProtectIsDebuggerPresent on v3.8.8.2040
Robustelli
Post by Robustelli »
Hello there,
I noticed a different behavior using the function VMProtectIsDebuggerPresent with the latest revision v3.8.8.2040.
The function returns 256 (decimal) even though no debugger is running
Same project compiled with v3.8.7.xxx works correctly.
Can someone confirm ?
Re: VMProtectIsDebuggerPresent on v3.8.8.2040
Show me your VMProtectIsDebuggerPresent declaration.
Robustelli
It's declared in WMProtectSDK.h
VMP_IMPORT bool VMP_API VMProtectIsDebuggerPresent(bool);
The size of "bool" is one byte, so 0x100 is equal "false"
Robustelli
My bad... I wrongly defined bool as an int
Thanks for your quick support
