3.8.9.2116 .NET not run on windows xp
xpxp
Post by xpxp »
I want to protect software that requires XP support based on .NET 4.0 with VMP.
Protected software runs normally on Win11 PC.
However, in XP, the software loads for about 10 seconds and then terminates.
-XP event log-
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.TypeInitializationException
Stack:
Re: 3.8.9.2116 .NET not run on windows xp
Could you send a very simple example (original EXE+VMP files) that shows your problem?
xpxp
Post by xpxp »
Admin wrote: Tue Jul 02, 2024 5:12 am Could you send a very simple example (original EXE+VMP files) that shows your problem?
Where should I send it?
xpxp
Post by xpxp »
Admin wrote: Tue Jul 02, 2024 12:51 pm[email protected]
Even applications with a basic hello world will not work.
I am uploading this as an attachment due to a gmail sending issue.
xp_issue.zip
(804.19 KiB) Downloaded 390 times
xpxp
Post by xpxp »
Hello Admin.
Any update for this issue?
Fixed in the 2119 build.
xpxp
Post by xpxp »
Admin wrote: Wed Jul 03, 2024 6:28 pm Fixed in the 2119 build.
thx. issue fixed.
