Hey everyone,
I'm very satisfied with the purchase of VMProtect. I need to virtualize all the functions inside my project. Adding functions via the .MAP file is very easy! However, when I try to add all functions, VMProtect prompts me with the message "Out of resources" and hangs itself. It happens on every computer I tried to do so. I have 8gb of ram, and the harddrive is not full either( in the resource monitor everything looks ok and VMProtect is only using 54 mb ).
Is there any way to solve this problem?
Regards,
R4z8r
Out of system resources?
Re: Out of system resources?
There's no reason to virtualize absolutely everything, it is enough to protect only critical parts of code.
However, VMProtect should not show such messages, so please send EXE, MAP and project files to [email protected]
Yes, you are correct. I just wanted to test the performance with all functions virtualized( why not virtualize them all when the performance is almost the same ), but my program didn't work quite normally anymore, so it's solved
Could you please send the files to [email protected]
Thank you
Thank you
Thanks. This bug will be fixed in next version of VMProtect (2.05).
Do you have an ETA for 2.05 I am now running into this frequently as my protected sections has grown.
I`ll send you the fixed 2.04 tonight.
Hi Admin,
I don't think the problem is completely gone I did a lot of open protect then close the file and the problem occurred again. It doesn't bother me just thought I would let you know.
Try to use 2.05I don't think the problem is completely gone I did a lot of open protect then close the file and the problem occurred again. It doesn't bother me just thought I would let you know.
