I downloaded new version 2.04
and compile example under MinGW.
It can not find section("Test marker")
after encrypt ,windows popu message 'Microsoft Application Error Reporting (Microsoft Corporation)'
work under winxp and gcc version 4.4.1 (TDM-2 mingw32)
Can not get mingw example to work.
Re: Can not get mingw example to work.
Please send your example (EXE+MAP+VMP files) to [email protected]
Thank you for the report. This bug will be fixed in the next version (2.05).
