Script for Extra Protection
fatalerror
Post by fatalerror »
Okay i decided to write a script to better virtualize the Entry Point. But it doesn't seem to work because P.ExtAddresses.Count is always zero is this an error? or did i do something wrong? BTW i never coded in Delphi so it could be
my fault :).
procedure OnBeforeCompilation;
var A, I:Integer;
    Address:Int64;
    EA:TExtAddresses;
    P:TVMProcedure;
    NewP:TVMProcedure;
    Instruction:TIntelRecord;
     for I := 0 to VMProtector.Count - 1 do
          P := VMProtector.Procedures[I];
          if P.Name = 'EntryPoint' then
             P.IncludedInCompilation := True;
             P.CompilationType := ctUltra;
             P.CompilationOptions := [coCheckCRC, coEncryptRegs, coEncryptValues];
             EA := P.ExtAddresses;
             Writeln(Format('Protecting %d additional procedures', [EA.Count]));
             for A := 0 to EA.Count - 1 do
                  Address := EA[A];
                  Writeln(Format('Adding address %x for protection', [Address]));
                  NewP := VMProtector.AddByAddress(Address, ctUltra, True);
                  NewP.CompilationType := ctUltra;
                  NewP.CompilationOptions := [coCheckCRC, coEncryptRegs, coEncryptValues];
Re: Script for Extra Protection
Do you want to add the EntryPoint`s calls into the list for protection?
fatalerror
Yes is that possible?
Try this script:
var I,J:Integer;
    NewProcedure,EntryPointProcedure:TVMProcedure;
    CurRecord:TIntelRecord;
    FirstOperand:TOperand;
  with VMProtector do
    I:=IndexOfAddress(InputFile.EntryPoint);
    if I>-1 then
      EntryPointProcedure:=Procedures[I];
      for J:=0 to EntryPointProcedure.Count-1 do
        CurRecord:=EntryPointProcedure[J];
        if CurRecord.CommandType=cmCall then
          FirstOperand:=CurRecord.Operands[0];
          if FirstOperand.OperandType=[otValue] then
            NewProcedure:=AddByAddress(FirstOperand.Value,ctUltra,True);
            if NewProcedure<>nil then
             NewProcedure.CompilationOptions:=[coCheckCRC,coEncryptRegs,coEncryptValues];
P.S. TVMProcedure.ExtAddresses - it`s a user defined external addresses (not is calls).
fatalerror
Ah thank you very much I tried doing it that way with TIntelRecord but docs do not say there is OperandType and Operands so i thought it was not possible that way.
fatalerror
BTW: Scripting part of VMProtect is a very powerful and great feature if used correctly. Maybe put that information on main site 8). i didn't know how good it is until recently when I started reading the docs.
The description of TIntelRecord.Operands (TOperand, TOperandSize, TOperandType, etc.) will be added to the help file in next versions.
henrik
Post by henrik »
This is a nice script, indeed :D
But during trying, this error occurs:
[Error] 10002C250: Minimal size of procedure for compilation is 5 bytes
Reason: the called subroutine is just:
000000010002C250 33C0 xor eax, eax
000000010002C252 C3 ret
Is there a way to check whether a subroutine is too small to be added with AddByAddress in the script, so this error does not occur - or there a way to silently skip these subroutines w/o terminating the protection process?
Thanks in advance,
Henrik
henrik
The check of length can be made by script:
var I,J,K,R:Integer;
    ProcLength:Longint;
  with VMProtector do
    if I>-1 then
        // need only CALL instruction
          // the first operand must be value
            // new procedure is added
              ProcLength:=0;
              K:=NewProcedure.IndexOfAddress(NewProcedure.Address);
              // need start index of procedure entry
              if K>-1 then
               for R:=K to NewProcedure.Count-1 do
                 CurRecord:=NewProcedure[K];
                 if CurRecord.Address<>NewProcedure.Address+ProcLength then
                  break;
                 ProcLength:=ProcLength+CurRecord.DumpLength;
                 // optimization
                 if ProcLength>=5 then
                  break;
              // the check of length
              if ProcLength<5 then
               NewProcedure.Free
henrik
Post by henrik »
Wow :shock:
Henrik
