Unexplained crashes.
Locked
bigguy
Post by bigguy »
Hello, I am attempting to manual map a dll into a process. If the dll is packed with vmp lite and kernel+usermode debugging is on it crashes. Without debugging on, it doesnt.
It gave a 0x0000004 error (similar to that). It works on my pc but not others, very odd.
Re: Unexplained crashes.
Do you mean the message "Initialization error 4"?
bigguy
Post by bigguy »
Here are the errors on other peoples computers, on mine it works all the time.
Has something to do the kernel option of VMProtectIsDebuggerPresent, or even the debugger + kernel option in the VMProtect application.
Error 1:
Unhandled exception at 0x1000B75B: 0x80000004: Single step.
Error 2:
Exception thrown at 0x771ADA51 (ntdll.dll): 0xC0000005: Access violation reading location 0x00000008
It seems your maual loaded DLL doesn't support exceptions. Try to use LoadLibrary instead of your method.
Do you really think that your DLL is invisible in the memory if you loaded it manually? :))
Please notice that the main problem - it is your manual loading method. It doesn't support exceptions even if a DLL will use something like this:
try {
  throw ...;
} catch (...)
Locked
