packing .exe file, destorted resources
gkoukou
Post by gkoukou »
Hi,
When selecting the option to pack the output .exe I noticed that my bitmap resources appear destorted (probably due to the compression method).
Is it possible to create a packed .exe file without touching specified/or all resources?
Regards,
George
gkoukou
Re: packing .exe file, destorted resources
Post by gkoukou »
I noticed the "move resources to the end of file" option. I was just wantering if there is a method for packing only selective resources
Please send your test application with such resources to [email protected]
gkoukou
Post by gkoukou »
Ok I will create a demo.exe for you.
In the mean time could you tell me if there is a method (ie using script) for packing selective resources only?
Unfortunately VMProtect doesn't have such feature.
gkoukou
Post by gkoukou »
Ok I can live with the "move resources to the end" option then
But why when I used this option the final .exe is much bigger in size?
In my case size of .exe without using the option ~20 mb and after using the option ~36mb. I have some large binary resources in this executable
