Protection help
robert
Protection help
Post by robert »
I have bought VMProtect License 4 days back and I need help for Strong protection against Crackers, the ultimate goal of buying this product is to protect my application from crackers. need proper guidance from Support As I am new for this.
1. How can I use Map file with vmprotect
2. what is the method of using Markers
3. what is difference between Virtulize and Mutat
4. Where to use Mutat and where Virtulize
Thanks
robert
Re: Protection help
http://vmpsoftware.com/vmprotect/user-manua ... a-map-file
http://vmpsoftware.com/vmprotect/user-manual#using-markers
http://vmpsoftware.com/vmprotect/user-manual#glossary
We recommend use the virtualization for all parts of critical code.
robert
Re: Protection help
Post by robert »
Thanks for your reply but this is not proper Guide
http://vmpsoftware.com/vmprotect/user-manual ... -map-file/
This is not how to use Map file with Vmprotect, this is how we get Map file from project side
I need proper guide how to use Map file when we load an exe into VMprotect and where to use Map file.
Thanks
robert
Re: Protection help
Just open EXE/DLL file in VMProtect and add required functions for protection.
