Macro vs API Call
mal27
Macro vs API Call
Post by mal27 »
In old versions you had macros defined.
If i buy newest vmprotect can i use those? Also would you advise using them in terms of mutation complexity, algorithm and whatever?
Re: Macro vs API Call
mal27
Post by mal27 »
Okay it seems they have no bad effect. But why have they been removed from sdk?
Please notice that ASM includes doesn't supported by many compilers (especially for x64 applications), so you have to use API calls instead of ASM macros.
