Address is already used by function error
skiselkov
Post by skiselkov »
I'm building a Windows DLL on Linux and using VMProtect on Linux to protect the resulting DLL. But for some reason, some functions seemingly are generating address conflicts (see screenshot). The only way I can work around this is to turn off protection for the conflicting functions, which is not really something I'd want to do. Checking the load addresses, the functions clearly don't use the same addresses, so this must be something internal to VMProtect. Doesn't matter if I use Virtualization, or Virtualization + Mutation. This only happens when trying to protect the windows DLL. The Linux shared library version of the same code is working perfectly OK.
I saw another topic on the forum regarding this, but the thread contained no resolution information. How do I work around this issue?
Re: Address is already used by function error
Could you send us a test example (original DLL+VMP files) that shows your problem?
skiselkov
Post by skiselkov »
Certainly. Do you have an e-mail or FTP server I can upload this to? I saw [email protected] being used by some others. Is that a valid target?
Please send to [email protected]
skiselkov
Post by skiselkov »
E-mail sent. Thank you for your help!
Please try the 938 build.
skiselkov
Post by skiselkov »
The new version works perfectly! Thank you very much, I'm very impressed at the speed of your support!
skiselkov
Post by skiselkov »
I believe I've run into the same issue when trying to compile a Mac build of my library using VMProtect 3.1.2.938 on Linux. It's not detecting the end marker and reading past the VMProtectEnd marker, resulting in multiple protected code segments overlapping. I've sent the binary to [email protected]. If you could please take a look at this, I'd very much appreciate any help.
Try the 939 build.
skiselkov
Post by skiselkov »
Thank you. Now I can compile the file, but when I try to load the dylib into the application, I get this error:
dlerror:dlopen(.../mac.xpl, 6): no suitable image found.  Did find:
	.../mac.xpl: malformed mach-o image: segment .vmp1 file content overlaps segment .vmp
I used the compilation defaults in VMProtect, just to make sure I didn't break something on my own.
skiselkov
Post by skiselkov »
Just FYI, I've been able to get the dylib to load into the application when by disabling output packing in the VMProtect options. Is that a known limitation for dynamic libraries on Mac?
It just new useless checks in dyld:
https://opensource.apple.com/source/dyl ... .auto.html
skiselkov
Post by skiselkov »
Thank you for clearing that up. Unfortunately I can't change the library loading routines (they're done by a 3rd application), so I had to disable output packing on Mac.
Try the 947 build.
