Not enough space for the new segment in the file header
nobrain90
Post by nobrain90 »
I use the VMProtect demo (v3.2) to test before I buy.
With an exe, then a dll, everything works ! :)
But I encounter an error with a WinDDK driver : "Not enough space for the new segment in the file header".
The error persists even if I change the "DRIVER_ALIGNMENT" value in the sources before recompiling (= 0x1200).
This is my current setup :
Memory Protection : Yes
Import Protection : Yes
Debugger : User-mode + Kernel-mode
Virtualization Tools : No
Strip Debug Information : Yes
Key Pair Algorithm : RSA 4096
Do you have any idea, please ?
Thank you
ovid
Re: Not enough space for the new segment in the file header
Post by ovid »
why you change this from 0x1000 to 0x1200 what reason?
also I think you should use your protection based on hwid inside not use VMP for drivers.
anyway just my opinion, admin is one that solve problems here.
nobrain90
Post by nobrain90 »
Hello ovid,
Only for test :wink:
Why please ?
Thank you
a47
Post by a47 »
Have same issue(not enough space for the new segment in the file header) when trying to protect linux so in ultimate windows version(spirt****@pm.me) and with linux x64 trial too
file example: https://share.riseup.net/#7jm-uu0nAAsIAW9DiCM9Hg (cannot attach here cuz "Invalid file extension: libLLVM-3.9.so")
Does VMP 3.2 support elf64 so shared libs?
VMProtect supports elf64 binaries.
a47
Post by a47 »
Nice, but what should i do with this compilation error? Where is the root? May be i should use another gcc flags? Will this error fixed?
Do you use our SDK?
a47
Post by a47 »
No i dont, should i?
I'm trying to protect free as in freedom binary(https://github.com/lwss/fuzion)
In this case there is not enough free space in the file header.
a47
Post by a47 »
Yes, but is there way for protection this project? After ur question I've tried to include vmprotectsdk.h and set up markers for some functions, but result is the same.
You can use the following trick with SDK name: "./././././././././././././libVMProtectSDK.so" (many many /./.). This string is placed in the file header and after protection the place of this string will be used for creation of a new segment(s).
a47
Post by a47 »
how to perform it? could u provide an example?
Try this:
gcc -L././././././././././
a47
Post by a47 »
set(CMAKE_SHARED_LINKER_FLAGS "${CMAKE_SHARED_LINKER_FLAGS} -L ./././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././src/libVMProtectSDK64.so")
didnt work
Please read help about "-L" more carefully.
