it seems to me if you only use expert mode it will not show entry point when its unmarked
if you turn off expert mode, the entry point will show and u can select virtualization for it. it will then show on expert mode.
is this a bug?
bug - problem vming entry point from expert mode
Re: bug - problem vming entry point from expert mode
Please send us a test application with this problem.
P.S. Only markers and strings added to the list of protected objects automatically. Other functions from MAP file (including EntryPoint) add by user (in expert mode through "Add procedure").
