VMProtectGetSerialNumberState witch flags in
ouiouioui
Post by ouiouioui »
Hello, how find in result of VMProtectGetSerialNumberState witch flags set ?
If SERIAL_STATE_FLAG_DATE_EXPIRED and SERIAL_STATE_FLAG_MAX_BUILD_EXPIRED are set i get 72 so what is the reverse for get the flags
I don't how get all flags set in VMProtectGetSerialNumberState.
I use Delphi.
Many thanks for your help.
Regards, Alexandre.
Re: VMProtectGetSerialNumberState witch flags in
Please see the example from VMProtect Ultimate\Examples\Licensing\Delphi:
unit Unit1;
  // set the serial number
  nState := VMProtectSetSerialNumber(PAnsiChar(AnsiString(edSerialNumber.Text)));
  // parse serial number state
  edInfo.Lines.Clear;
  edInfo.Lines.Add(Format('VMProtectSetSerialNumber() returned: 0x%.8X', [nState]));
  if nState and SERIAL_STATE_FLAG_CORRUPTED <> 0 then
   edInfo.Lines.Add(#9'SERIAL_STATE_FLAG_CORRUPTED');
  if nState and SERIAL_STATE_FLAG_INVALID <> 0 then
   edInfo.Lines.Add(#9'SERIAL_STATE_FLAG_INVALID');
  if nState and SERIAL_STATE_FLAG_BLACKLISTED <> 0 then
   edInfo.Lines.Add(#9'SERIAL_STATE_FLAG_BLACKLISTED');
  if nState and SERIAL_STATE_FLAG_DATE_EXPIRED <> 0 then
   edInfo.Lines.Add(#9'SERIAL_STATE_FLAG_DATE_EXPIRED');
  if nState and SERIAL_STATE_FLAG_RUNNING_TIME_OVER <> 0 then
   edInfo.Lines.Add(#9'SERIAL_STATE_FLAG_RUNNING_TIME_OVER');
  if nState and SERIAL_STATE_FLAG_BAD_HWID <> 0 then
   edInfo.Lines.Add(#9'SERIAL_STATE_FLAG_BAD_HWID');
  if nState and SERIAL_STATE_FLAG_MAX_BUILD_EXPIRED <> 0 then
   edInfo.Lines.Add(#9'SERIAL_STATE_FLAG_MAX_BUILD_EXPIRED');
ouiouioui
Post by ouiouioui »
Many thanks for your help. It's perfect.
